So been planing the PC build since July time and finally got the money and tools.
The idea behind this case is for LAN events, as I have got kinda annoyed of lugging my PC in separate bits (Keyboard, monitor, mouse, system, headphones) to LAN.
I have set it up with the basics for now to get it running and will add additional components/modifications over time.
Right now just asking for some feedback from you guys and to help give suggestions.
System:
Core i5 4th Gen 3.5 gHZ
AMD r7770 fx 2gb (Upgrading)
PSU 550 Watt +80 gold plus
SanDisk 60GB SSD
Asus asus h87m-plus
D-link 300 wireless nano adapter
Logitech Wireless keyboard/Track-pad
(Pieces of the case where taken from an old case that I used)
EDIT: New photos of how I'm thinking on attaching the monitor and a little bit of air cooling (Still thinking it through :S)
post-157001-0-03366000-1415023494_thumb.
post-157001-0-93438300-1415023507_thumb.
post-157001-0-74825300-1415023520_thumb.
post-157001-0-42624200-1415023527_thumb.
post-157001-0-33220100-1415023534_thumb.
post-157001-0-02291200-1415023771_thumb.
post-157001-0-82600400-1415061272_thumb.
post-157001-0-77290300-1415061287_thumb.
https://linustechtips.com/topic/243941-briefcase-pc-wip/
so DIY overkill laptop? cool!
5.1GHz 4770k
My Specs
Intel i7-4770K @ 4.7GHz | Corsair H105 w/ SP120 | Asus Gene VI | 32GB Corsair Vengeance LP | 2x GTX 780Ti| Corsair 750D | OCZ Agility 3 | Samsung 840/850 | Sandisk SSD | 3TB WD RED | Seagate Barracuda 2TB | Corsair RM850 | ASUS PB278Q | SyncMaster 2370HD | SyncMaster P2450
https://linustechtips.com/topic/243941-briefcase-pc-wip/#findComment-3343265
Pretty much the idea man :)
depending on what GPU you upgrade to, 550W may not cut it.
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/243941-briefcase-pc-wip/#findComment-3343302
also, you should add a keyboard that you can slide out from the bottom when its open :)
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/243941-briefcase-pc-wip/#findComment-3343322
Going to upgrade to my main GPU for my desktop which is gtx 760, but may go for 780 still figuring at power levels :S
780 minimum is 600W
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/243941-briefcase-pc-wip/#findComment-3343348
Awesome! Have seen a brief case pc on pcpartpicker before, but it is awesome to see that the amount of people that makes their own cases is growing every day.
Its fun doing it as well, and more simple then a lot of people think (Just need the tools and the know how) :)
https://linustechtips.com/topic/243941-briefcase-pc-wip/#findComment-3343379
780 minimum is 600W
You can run a GTX 780 easily with a 500w unit. If OP does not OC too much and the CPU is not the FX-9590 ;)
REMEMBER TO QUOTE SO I GET A NOTIFCATION! Add me on Steam: http://steamcommunity.com/id/Shroomster/ Review(s) more to come
https://linustechtips.com/topic/243941-briefcase-pc-wip/#findComment-3344243
Pretty fucking awesome. Congrats!
CPU: Intel Core i7-4790k | CPU Cooler: Noctua NH-D15 | Motherboard: ASUS Sabertooth Z97 MARK 1 | Memory: Kingston HyperX FURY 16GB 1866MHz | GPU: Gigabyte GeForce GTX 770 4GB Windforce
Storage: Samsung 840 EVO | PSU: CM Silent Pro 720W | Case: Phanteks Enthoo Luxe | Headset: Corsair Vengeance 2100 | Keyboard: Logitech G710+ | Mouse: Razer DeathAdder Chroma
"You see, one can only be angry with those he respects." - R. Nixon
https://linustechtips.com/topic/243941-briefcase-pc-wip/#findComment-3344338
true. 600W is just the recommended. And where is the fun in a good GPU if you dont OC? :D
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/243941-briefcase-pc-wip/#findComment-3345369
https://linustechtips.com/topic/243941-briefcase-pc-wip/#findComment-3345402
I don't think a briefcase has the best possible airlfow :D
https://linustechtips.com/topic/243941-briefcase-pc-wip/#findComment-3345811
