If I use a Y-spliiter and have my motherboard deliver 7 volts for instance, would both fans run at 3.5 volts each? Or will they both run at 7 volts
Both run at 7 volts
My setup: i5 3570K  - Corsair H100i - MSI Z77 GD65 - 256 GB Samsung 840 pro SSD - Corsair AX760i - Gigabyte GTX 670 Windforce 2GB - 4x4 GB Crucial Ballistix Tactical Tracer RAM - Corsair Carbide 500R (modded side window)
https://linustechtips.com/topic/243847-y-splitter-cable/#findComment-3340024
If you use a Y splitter, the voltage stays the same, but the amperage doubles. The motherboard fan header should be able to do 1A easily, look in your motherboard manual.
2x 12V fans @ 0.25A
Main: i7 2600 | ASUS P8Z68-V | 2x4GB Vengeance 1600 | GTX 580 | WD Blue 1TB | Antec TP-650C | NH U12S | W7 x64
Backup: X6 1090T | MSI K9A2 Platinum | 4x2GB XMS2 800 | GTX 550Ti | WD Blue 1TB |  Antec VP-450 | CM TX3 | W7 x64
https://linustechtips.com/topic/243847-y-splitter-cable/#findComment-3340035
Mind me asking whats 'amperage'?
https://linustechtips.com/topic/243847-y-splitter-cable/#findComment-3340075
