This is what i have so far!
This is what i have so far.....
Case – Corsair Graphite 230T Case with Window Battleship Grey
CPU – Intel Core i7 4790K
Motherboard – MSI Z97 Gaming 7 Motherboard
CPU Cooler – Unsure on what to get, suggestions?
GPU – Gigabyte GeForce GTX 980 G1 Gaming 4GB
SSD – Samsung 840 EVO Series 120GB SSD
RAM -Corsair Vengance 16GB DDR3
Hard Drive – Western Digital WD Blue 1TB WD10EZEX
OS – Windows 7 64bit
Total – $2225.00
I would appreciate any suggestions recommendations or criticism, im new to building PCs and its confusing but i now have a rough understanding and have made this! i don't know what to do about cooling aswell, anyway thanks if you help :D
https://linustechtips.com/topic/243843-first-pc-build/
Total – $2225.00
can you please you pcpartpicker.com to make a build list? this is kind of confusing
regarding your computer build, this is what you ahve right now, I don't know how you got calculated the price to be that high
currently, you are missing RAM, cpu cooler and a PSU
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($329.97 @ OutletPC)
Motherboard: MSI Z97-GAMING 7 ATX LGA1150 Motherboard  ($169.98 @ OutletPC)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE Video Card  ($629.98 @ NCIX US)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($88.98 @ OutletPC)
Total: $1425.38
Generated by PCPartPicker 2014-11-03 04:35 EST-0500
| --- My Stuff --- |
Computer: Apple Late-2008 Macbook Pro ; -Haguro- build: http://linustechtips.com/main/topic/296613-wip-project-haguro-x99-hackintosh-workstation/|
Mobile Devices: Apple 32GB 1st gen Ipad Mini ; Apple 16GB Iphone 5s ; Apple Ipod Classic 80Gb 5th Gen ; Apple Ipod Classic 120Gb 6th Gen ; Apple Ipod Classic 160Gb 7th Gen ; Apple Ipod Nano 16Gb 6th Gen
https://linustechtips.com/topic/243843-first-pc-build/#findComment-3340185
Total: $1425.38
He's got Corsair Vengeance Ram,  and I would recommend a different Ram if you are having a red theme build.
https://linustechtips.com/topic/243843-first-pc-build/#findComment-3340203
for the cooler, do you want your pc to be water or liquid cooled? are you planning to extreme over clock your cpu and gpu?
for RAM, I recommend getting g skill's memory, it's not top of the line but its decent and will definitely do the job, if you want the best ram, maybe you can get some dominator platinum from corsair?
for the PSU, you should get the EVGA 220-G2-0750-XR power supply, it's quite cheap for a 80+ gold power supply and it has upgradeability in mind and it's also from a trustworthy company
| --- My Stuff --- |
https://linustechtips.com/topic/243843-first-pc-build/#findComment-3340248
how do you know, am I miss reading something or is there something that he didn't tell us?
| --- My Stuff --- |
https://linustechtips.com/topic/243843-first-pc-build/#findComment-3340275
Total: $1425.38
also, is there a particular reason that you chose the MSI board? because there are plenty other Z97 boards that offers more feature for around the same price point from Asus or Gigabyte,
What is this build going to be used for? If you are only using this rig for gaming and not planning to do production or rendering, I would consider going for an I5-4690k instead, they will both offer around the same performance in games and you will save ~$100 to use on other equipments
| --- My Stuff --- |
https://linustechtips.com/topic/243843-first-pc-build/#findComment-3340375
Total: $1425.38
Total – $2225.00
This is what I see on my screen lol
https://linustechtips.com/topic/243843-first-pc-build/#findComment-3340420
Total – $2225.00
are this australian build ?
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($397.00 @ Centre Com)
Motherboard: MSI Z97-GAMING 7 ATX LGA1150 Motherboard  ($249.00 @ CPL Online)
Storage: Samsung 840 Pro Series 128GB 2.5" Solid State Drive  ($109.00 @ Mwave Australia)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE Video Card  ($839.00 @ CPL Online)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  ($145.50 @ Centre Com)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($145.00 @ CPL Online)
Total: $2177.50
Generated by PCPartPicker 2014-11-03 22:35 EST+1100
Current Build + Setup
AMD Ryzen 7 5700X | GIGABYTE B550 Aorus Pro v2 | CORSAIR Dominator Platinum 16gb 3600Mhz | GIGABYTE RTX 3070 AORUS MASTER OC 8 GB | NZXT H510 Elite | 2TB Seagate Barracuda 7200RPM | ADATA XPG GAMMIX S7 512GB M.2-2280 NVME | Corsair RM850 80+ Gold Modular PSU | NZXT Kraken X63 | Harman Kardon Soundstick 4 | Koorui 27E1Q
https://linustechtips.com/topic/243843-first-pc-build/#findComment-3341484
Total – $2225.00
What's your budget, location and what do you plan on doing with this build?
Use PCPartPicker, I mean it!
https://linustechtips.com/topic/243843-first-pc-build/#findComment-3343546
One thing I would recommend is a second SSD.  I put a 120 GB boot drive in my current PC, and even with installing most of my games and data on separate HDDs, the 120GB is just full of windows stuff.  I am planning to upgrade to a 240Gb (at a minimum) in the very near future.  If you already have the 120GB in hand, get a second and put them in RAID 0.
https://linustechtips.com/topic/243843-first-pc-build/#findComment-3343692
