So I want to build any mid-teir mining rig that uses normal GPUs, not ASIC cards. Also prefer an open air design. Can anyone make some suggestions? Thanks :)
Want a good game to play?  Check out Shadowrun: http://store.steampowered.com/app/300550/ (runs on literally any hardware)
another 12 core / 24 thread senpai...     (/. _ .)/     \(. _ .\)
https://linustechtips.com/topic/243836-2000-cryptocurrency-rig-help/
Mining is not profitable you are better of spending your money in the casino.
Dare you to most that on the Foling@home sub-forum. Seriously,while I respect your right to your opinion such comments aren't helpful on a build help post.
You could have said that it was for folding and not for mining coins.
. PREPARE FOR N00BNESS what's the difference
Well mining coins isn't profitable and folding is actually usefull for something and no I'm not a noob since I've mined and folded my self.
Cases are ususally hard to find so most people make  one them self.
A common used motherboard is Asrock h81 pro btc that board can use up to 6 gpu's
For the gpu's anything better than a 7950 from amd is a good choise
Psu: usually 2 1000w psu's per motherboard
thanks dude :). BTW I wasn't saying you were a noon, just me for not knowing what folding was
