Nzxt H440 or Phanteks Enthoo Pro?
InVeyd
Which do you like more?
/If you plan on a custom loop then Enthoo Pro
PSU Tier List | CoC
Gaming Build | FreeNAS Server
The NZXT H440 would be my choice.
CPU:Ryzen 9 5900X GPU: Asus GTX 1080ti Strix MB: Asus Crosshair Viii Hero RAM: G.Skill Trident Neo CPU Cooler: Corsair H110
i love the h440
Yes Yes Legalize Gay Marriage sure, but have you ever considered Weaponizing Gay?
CPU: I5 4690 3.5ghz || MOBO: MSI B85-G43 Gaming Board || RAM: 8GB Corsair Vengance Pro - Red || GPU: Gainward GTX770 Phantom 4gb || PSU: EVGA SuperNova 750W Gold || Case: Thermaltake Urban T31 || SSD: Corsair Force 120GB || HDD: 1TB WD Black
h440  :D
"Do as I say, not as I do" - Linus
​Quote me in a reply to me so I get a notification!
Help me decide! :(
Very different cases. Honestly, they're both amazing and you can't make a wrong choice here. Main differences: Phanteks Enthoo Pro is a very open air case, meant to move a lot of air through and keep it cool. Like djdwosk97 said, it'd probably be better for a custom loop since rads could get more air. On the other hand, the NZXT H440 is a "silent" case. It doesn't have many air vents so not as much sound can get out. The back also has sound-dampening material, which makes cable management a bit harder than the Pro. H440 will have slightly higher temps, but will be a few dB quieter, and could be silent if you used quiet components like air cooling and noctua fans meant to be quiet. Pro will let out slightly more noise, but you're temps will be a bit lower. Whichever is more important to you  :) . Personally, I'd go with the Enthoo Pro since I mainly use headphones and, with decent quality fans and rads, wouldn't hear much noise, and I don't mind noise if it isn't that loud.
You can do a pretty legit custom loop in the H440.
Yes, but the Pro is better
PSU Tier List | CoC
Agreed
Im planning on water cooling the cpu with h100i and gpu with kraken x31....
Go with whatever you think looks better, but I would get an H105, X61, Seidon 240m, H220x, or pretty much anything other than the h100i as it has mounting issues.
PSU Tier List | CoC
That's possible in both cases. Personally I'd go for the H440 because of the looks, both are ok cases with 1 main difference.
The Pro has optical drive bays and the H440 doesn't. If that doesn't matter to you, go for the one you like the most.
CPU: i7-4770K  Cooler: NZXT X60  GPU: Asus GTX 770 2GB  MB: Asus Maximus VI Hero  RAM: Corsair Vengeance 16GB 1600MHz  PSU: Be Quiet! 630 Watt  Case: NZXT H440
       Storage: 120GB Samsung 840 Evo + 1TB Seagate HDD  KeyboardCorsair K70 RGB  MouseG502 Proteus Spectrum  HeadphoneSennheiser HD598  Mic: Blue Snowball Ice
