I am not a new pc gamer but I am very unfamiliar to building them and selecting parts that work with one another. my budget is approximately $2500cdn for nothing other than the tower and components. i would like to have a computer than runs the majority of games in the high setting ranges if possible. thanks for the help and contributions.  its a clean slate i will need everything.
https://linustechtips.com/topic/243668-2500-rig-need-help/
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($373.99 @ Amazon)
CPU Cooler: NZXT Kraken X41 106.1 CFM Liquid CPU Cooler  ($106.98 @ SuperBiiz)
Motherboard: Asus X99-A ATX LGA2011-3 Motherboard  ($247.49 @ Amazon)
Memory: Crucial 16GB (2 x 8GB) DDR4-2133 Memory  ($194.99 @ Adorama)
Storage: Crucial MX100 512GB 2.5" Solid State Drive  ($208.97 @ SuperBiiz)
Storage: Seagate  3TB 3.5" 7200RPM Internal Hard Drive  ($119.99 @ Amazon)
Video Card: MSI GeForce GTX 980 4GB Video Card (2-Way SLI)  ($549.98 @ NCIX US)
Case: NZXT H440 (White/Black) ATX Mid Tower Case  ($99.99 @ Newegg)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($86.98 @ SuperBiiz)
Total: $2539.34
Generated by PCPartPicker 2014-11-02 19:29 EST-0500
It's a little... majorly* overkill.
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
https://linustechtips.com/topic/243668-2500-rig-need-help/#findComment-3336797
Total: $2539.34
This will destroy anything.
This is Comic Sans.
This is Comic Sans.                                If you can't tell the difference, you may need to see a specialist.
This is Comic Sans.
https://linustechtips.com/topic/243668-2500-rig-need-help/#findComment-3336859
I am not a new pc gamer but I am very unfamiliar to building them and selecting parts that work with one another. my budget is approximately $2500 for nothing other than the tower and components. i would like to have a computer than runs the majority of games in the high setting ranges if possible. thanks for the help and contributions.  its a clean slate i will need everything.
For a good gaming system one doesn't need anything beyond an i5-4690K and 8GB of memory with a decent gpu.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.97 @ SuperBiiz)
CPU Cooler: Swiftech H240-X 90.0 CFM Liquid CPU Cooler  ($169.99 @ NCIX US)
Motherboard: ASRock Z97 EXTREME6 ATX LGA1150 Motherboard  ($164.99 @ Newegg)
Memory: Avexir Core series 8GB (2 x 4GB) DDR3-1600 Memory  ($76.99 @ Newegg)
Storage: Samsung 840 EVO 1TB 2.5" Solid State Drive  ($399.98 @ OutletPC)
Video Card: EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 Video Card  ($569.99 @ Amazon)
Case: NZXT H440 (Blue/Black) ATX Mid Tower Case  ($129.99 @ NCIX US)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($104.99 @ NCIX US)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($90.26 @ OutletPC)
Total: $1937.15
Generated by PCPartPicker 2014-11-02 19:44 EST-0500
https://linustechtips.com/topic/243668-2500-rig-need-help/#findComment-3336907
