i am building a pc with 1700$ budget (israel so it is around a 1300$ pc in the us).
i would like to know what i could change with this price and looking for future proofing
cpu: intel core i5-4690k (over clocking).
gpu: gigabyte g1-gaming gtx 970 (over clocking).
motherboard: msi z97 gaming 5
case: nzxt phantom 530 black.
power supply: seasonic g series semi moduler 750 watt.
cpu cooler:: noctua NH-D14
case fans: 2x corsair air flow 120mm
ram: corasir vengence 2x4gb 1600mhz (approved for this mobo) (all ready owned).
hard drive : western digital blue 1tb
boot drive: intel ssd 530 series 120gb. (all ready owned)
https://linustechtips.com/topic/242890-help-with-pc-build/
There is no such thing as "future proofing", but why not get the newer generation i5-4690k?
i think he meant 4690k
First Build:
Case: Bitfenix Prodigy Black          GPU: MSI R9 270 Gaming@1050/1500         CPU: i5 4570          Motherboard: ASUS H81I Plus          PSU: Corsair CX600          RAM: 8GB Crucial Ballistix Sport XT         Cooling: 230mm Bitfenix Spectre Pro Intake; Corsair AF140 Rear Exuast; 2x120mm Stock Case Fans Top Exuast        Storage: WD Blue 1TB          OS: Windows 8.1 Pro 64 Bit
https://linustechtips.com/topic/242890-help-with-pc-build/#findComment-3327707
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.96 @ OutletPC)
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler  ($88.00 @ Amazon)
Motherboard: MSI Z97-G55 SLI ATX LGA1150 Motherboard  ($117.98 @ SuperBiiz)
Memory: Kingston Black 8GB (2 x 4GB) DDR3-1600 Memory  ($79.99 @ Newegg)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($109.97 @ SuperBiiz)
Video Card: EVGA GeForce GTX 970 4GB ACX 2.0 Video Card  ($335.66 @ Newegg)
Total: $1177.19
Generated by PCPartPicker 2014-11-01 16:29 EDT-0400
https://linustechtips.com/topic/242890-help-with-pc-build/#findComment-3327778
Praise be tomshardware!
Israel
Logic PC
Gold Top Computers
Plonter
Sky PC <--- sells pre-built rigs and PC parts
Zig Zag 2000 <--- sells pre-built rigs and PC parts
KSP <-- not the best selection but competitive prices and has information in English, Hebrew, and Russian
Zap <--- Department store that sells PC parts in addition to lots of other goods
Ivory
Wellcom
1 PC
Maybe you should think about the Noctua NH-D15 instead of the D14, it has better compatibility for high profile RAM. Apart from that everything seems solid, have fun!
https://linustechtips.com/topic/242890-help-with-pc-build/#findComment-3327979
Israel
Logic PC
Gold Top Computers
Plonter
Ivory
Wellcom
1 PC
thanks yea i am geting it from ivory just becuase i trust and know them really...
https://linustechtips.com/topic/242890-help-with-pc-build/#findComment-3331089
Corsair Vengeance memory is listed as incompatible with the NH-D14 cooler at http://www.noctua.at/main.php?show=compatibility_ram_gen&products_id=34&lng=en#DDR3_Corsair. You may want to consider the NH-U12S instead as it does not overhang the memory slots.
Unless you are planning another gpu the 550W G Series model would be more than enough. The 650W model would be fine for a two gpu system.
https://linustechtips.com/topic/242890-help-with-pc-build/#findComment-3331168
Unless you are planning another gpu the 550W G Series model would be more than enough. The 650W model would be fine for a two gpu system.i
it is the low profile version
https://linustechtips.com/topic/242890-help-with-pc-build/#findComment-3332611
