i have a msi z77ma-g45 mobo and vengence 2x4gb ram at 1600 mhz
whelp there is my problem the ram is running at 1333 mhz.
how do i get it to run at its full clock,
cpu: intel core i5 3470 over clocked at 4.0ghz
motherboard: msi z77ma-g45
videocard: evga gtx 550ti oc
550 watt power supply
intel series 530 120 gb ssd boot drive
https://linustechtips.com/topic/242882-help-with-memory-clock/
Have you set it to 1600 in the bios?
First Build:
Case: Bitfenix Prodigy Black          GPU: MSI R9 270 Gaming@1050/1500         CPU: i5 4570          Motherboard: ASUS H81I Plus          PSU: Corsair CX600          RAM: 8GB Crucial Ballistix Sport XT         Cooling: 230mm Bitfenix Spectre Pro Intake; Corsair AF140 Rear Exuast; 2x120mm Stock Case Fans Top Exuast        Storage: WD Blue 1TB          OS: Windows 8.1 Pro 64 Bit
https://linustechtips.com/topic/242882-help-with-memory-clock/#findComment-3327622
pop into your bios and select XMP profile 1 for your RAM or manualy set it to 1600mhz if there is no XMP profile for this RAM but from the informations i get there is a XMP profile.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/242882-help-with-memory-clock/#findComment-3327651
