Hard Drive Issues
Go to solution Solved by Godlygamer23,
I can't guarantee that you'll find one that is for your hard drive, but there are a butt ton on eBay. If possible, I would try finding one with a return policy perhaps. My exact search terms were "WD hard drive circuit boards."
Do you have access to the hard drive?
https://linustechtips.com/topic/242832-hard-drive-issues/#findComment-3327028
If you can, I would try putting it into a system to see if it'll power on at all. (I know you said it doesn't based on what the person said)
https://linustechtips.com/topic/242832-hard-drive-issues/#findComment-3327049
On eBay, there are a whole bunch of WD PCBs you can purchase.
https://linustechtips.com/topic/242832-hard-drive-issues/#findComment-3327096
ok so do u think to would be worth a try?
Maybe. What size hard drive is it? Capacity as well as physical size.
https://linustechtips.com/topic/242832-hard-drive-issues/#findComment-3327155
https://linustechtips.com/topic/242832-hard-drive-issues/#findComment-3327293
