Mobo: msi z97 gaming 7
I have been using this pc for a while , only recently pc got stuck at windows then I held down the reset switch for long for a restart. Now recently the pc is posting , initially the error code is 10 then i tried removing one stick of ram and all the hdd then clear cmos then the error code is E0 , cant find any info in manual ?
https://linustechtips.com/topic/242514-system-no-post-debug-led-e0/
Updated everything?
Only connect all the things you really need to boot to the computer (display to graphics card, not Mainboard) and then try to boot.
~ ThxAndBye
"You should remove any cats from the vicinity, because cats will cause all kinds of problems during CPU installation." -Linus
