I DON'T KNOW HOW TO IN SKILL THE GPU.... SO I bought a new power supply and a new graphics card(xfx double d r9 280x) but when I plug it in the computer.. Nothing happens.. The screen is just black
My mobo: msi 7778
Cpu: amd a-8 5500
Psu: rosewill 750w
Ram:?? 8 gigs
Gpu: on board hd 7560 trying to go to r9 280x
Please help!!
https://linustechtips.com/topic/241812-need-help-with-gpu/
Did you plug the display into the back of the graphics card?
https://linustechtips.com/topic/241812-need-help-with-gpu/#findComment-3314457
yes
Was it plugged in? Did the fans on the gpu spin up?
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/241812-need-help-with-gpu/#findComment-3314559
If I take off the gpu it starts up normal.. Video and everything
Boot off of integrated graphics, go into the bios, and make sure PCIe / External graphics is enabled.
PSU Tier List | CoC
https://linustechtips.com/topic/241812-need-help-with-gpu/#findComment-3314671
Ensure your screen is on the correct input. Do it manually even it if it is, sometimes they don't switch properly or wake up right.
https://linustechtips.com/topic/241812-need-help-with-gpu/#findComment-3314849
