Hi I'm practicing javascript at the moment,I'm doing these problems where I found on the internet where you have to code a program that does the follwoing.
I managed to get  the first one by using an if else but when I tried the if else again on the other numbers it did not work.
Any help?
I'm really new to javascript.
Determine whether the following expressions are true or false:
1. !true || !false
2. (true && !false) && (false || !true)
3. (4 > 5) || true
4. ("this" != "that") && ("zebra" > "aardvark")
5. ((4 >= 6) || ("grass" != "green")) && !(((12 * 2) == 144) &&
true)
https://linustechtips.com/topic/241549-javascript-help/
notification
1. !true || !false
true
false
3. (4 > 5) || true
true
true
5. ((4 >= 6) || ("grass" != "green")) && !(((12 * 2) == 144) && true)
true
Mini-Desktop: NCASE M1 Build Log
Mini-Server: M350 Build Log
https://linustechtips.com/topic/241549-javascript-help/#findComment-3310818
Also, javascrpt if/else seems to work just fine for all of these problems as far as I tested
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
https://linustechtips.com/topic/241549-javascript-help/#findComment-3310844
sure. Those are all logical/boolean expressions that evaluate to an boolean value, which is needed in an if-then-else-statement
https://linustechtips.com/topic/241549-javascript-help/#findComment-3310867
I know you can mentally solve them but the problem asked me to do a piece of code to prove if they are true or false
.sorry should have mentioned that in the post xD
https://linustechtips.com/topic/241549-javascript-help/#findComment-3310914
var x = !true || !false;console.log(x)var y = ((4 >= 6) || ("grass" != "green")) && !(((12 * 2) == 144) && true);console.log(y)
https://linustechtips.com/topic/241549-javascript-help/#findComment-3310931
