I recently found these fans and am wondering if they're actually as good as Noiseblocker ones...?
http://www.pccasegear.com/index.php?main_page=product_info&cPath=9_1485&products_id=23515
Thanks
Yes, as far as i know, they are produced by Noiseblocker. It's a coop between Phobya & Noiseblocker.
Christopher Kruse | Webdeveloper (Interface & Applications)
i7 3770k (3233C Batch) @ 4.2ghz | Asus P8Z77 WS | Gigabyte 780 Ti OC  | Corsair Vengeance LP 1600 32GB DDR3 | Samsung 850 EVO 500GB +2x Samsung 840 EVO 250GB + Samsung 830 256GB + 4x WD30EFRX, 2x WD30EZRX, 1xWD20EARS | Corsair AX750 + Bitfenix Extensions | Fractal Design Define XL R2 + Xigmatec 3in3 Hotswap Cage | Noctua NH-D15 + Thermal Grizzly Kryonaut, 5x Noctua NF-P14s redux-1500 PWM | Peripherals: Logitech G502 + Corsair K70 RGB + Red 40A-L O-Rings | Sound: Denon AVR 2807 via HDMI + 2x Nubert nuPro A-20 + 1x B&W CC6 Center | SoundMagic E10 | Jabra Speak 410
https://linustechtips.com/topic/24142-nb-eloop-fans/#findComment-305988
Thanks for the quick reply
Would these be compatible with a Lamptron fan controller?
I'm not entirely sure how non-PWM eLoops react to speed regulations. Generally yes, i don't see why not.
But you should get a second opinion on that matter.
https://linustechtips.com/topic/24142-nb-eloop-fans/#findComment-305995
It depends if you have a PWM controller (usually 4-pin) or a voltage controller (usually 3-pin). Plugging a non-PWM fan onto a PWM fan controller can cause issues with some fans. But I think we are talking really cheap fans, so you should be good. I have tried the eLoops myself, but then went with the Noiseblocker Multiframe-Series for the extra silence.
https://linustechtips.com/topic/24142-nb-eloop-fans/#findComment-306163
Got both Multiframe and eLoop in my system :D Love them both for their respective targets.
https://linustechtips.com/topic/24142-nb-eloop-fans/#findComment-307890
