Build for a m8
Solved by hawaiims,
He doesn't want to spend a ton of money.
The thing that I didn't think about but now realize is that an i3 will certainly bottleneck some games with an r9 280 or even a 760. That's one of the reasons why I would go for the i5 instead.
The price difference is only about $70 CAD, so maybe to make that gap smaller I would just use the free CPU cooler.
Also, I've found some new components you could get to price match that are cheaper:
You can get Memory express to price match the H87M-P33 motherboard for around $50 CAD
