Hey.
I would like to know how much watt does the Desktop PC listed below needs.
This Pc might come with some fans btw.
Thanks
PC -
More Information
  • Accelerate your gaming sessions with a liquid-cooled AMD FX-9370 4.4GHz eight-core CPU and AMD Radeon R9 270X graphics for smooth framerates and stutter-free multitasking
  • Large 120GB SSD boot drive provides lightning-quick boot times, while the 2TB data drive has enough space for all your applications and media
  • Ensure stutter-free computing with 16GB of DDR3 RAM
  • Includes USB Gaming Keyboard and Mouse, Driver Discs, and Power Cord
  • Features two available internal 3.5" hard drive bays (three total)
  • Features six available external 5.25" optical bays (nine total)
  • Connect your computer with a bevy of ports including DVI outputs, an HDMI output, a DisplayPort, and both SuperSpeed USB 3.0 and USB 2.0 ports
Base Features   Processor Type AMD FX-9370 Processor Speed 4.4 GHz RAM 16 GB (1333 MHz DDR3) Hard Drive Capacity 2 TB; 120 GB SSD Hard Drive Speed (Revolutions Per Minute) 7200 rpm; Not Applicable Optical Drive 24X DVD±RW Dual-Layer Super-Multi Drive Pre-loaded Operating System Windows 8.1 64-Bit Graphics Card AMD Radeon R9 270X Dedicated Graphic Card Yes Video Memory 2 GB TV Tuner No Display   Built-in Monitor No HDCP Compliant No Screen Size/Type Not Applicable Native Screen Resolution Not Applicable Touchscreen Display No Audio   Sound Card Integrated - Realtek ALC892 Audio Output High Definition 7.1 Channel Surround Speakers No Speaker Wattage Not Applicable Integrated Microphone No Microphone Input 1 x Front; 1 x Back Line-In Input 1 x Back Line Out 1 x Front; 1 x Back Digital Input No Digital Output 1 x Back Networking   Ethernet Port 10/100/1000 Integrated Wi-Fi No Integrated Bluetooth No Inputs & Outputs   Webcam No Keyboard Full-size; USB; Gaming Mouse Optical; USB; Gaming Remote No Modem No USB Ports 10 x USB 2.0 (2 front; 8 rear) 3 x USB 3.0 (1 front; 2 rear) FireWire (IEEE 1394) 1 Back E-SATA 2 Back DVI Output 2 Back HDMI Output 1 Back Other Input or Output Ports 1 DisplayPort - Back Computing Features   Processor Cache 8 MB L3 Available Hard Drive Bays 3 Internal 3.5 Inch (2 Available) Available Optical Bays 9 External 5.25 Inch (6 Available) Available PCIe Slots 4 PCIe x16 Slot (3 Available); 2 PCIe x1 Slot (2 Available) Available PCI Slots 1 PCI Slot (1 Available) Available AGP Slots Not Applicable Available Memory Slots 4 Memory Slot (2 Available) Removable Storage No Power Supply   Energy Star Qualified No Software   Operating System Language English Loaded Software No Product Features   Colour Black Width 31.8 cm Height 48.3 cm Depth 52.1 cm Width (Inches) 8 in Height (Inches) 19 in Depth (Inches) 20 in Weight 14.5 kg Warranty Labour 1 Year(s)
https://linustechtips.com/topic/241323-need-help-picking-power-supply/
A decent 500w would be plenty.
are you sure thats enough ? because it comes with 800 watt shit power unit.
Yes. http://www.hardocp.com/article/2014/03/10/amd_radeon_r9_270x_270_video_card_review/11#.VFLUN5DF-UE
What about the CPU and the liquid cooling and also fans? do you think it might be enough for that too?
The power draw measured was for an entire system that is more power hungry than yours--not just the graphics card.
