So a friend of mine got the same internet as me.Since he can't afford internet i drilled a hole into the wall and wired him some ethernet cable from my modem.The problem is that the speed is very very low it's stuck at 20 mbps.I thought that the cable is damaged or something but i tested with my laptop and it goes as it should to 500 mbps.Any advices?
Yes his pc old but i don't think that is restricted by the lan controller
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
https://linustechtips.com/topic/240984-network-speed-problems/
If his ethernet port is only a 20 mbit port then it could be an issue. Obviously it's hs pc if it is too low on his pc but normal on yours
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/240984-network-speed-problems/#findComment-3303314
  • 2 weeks later...
