I am in need of a new gaming pc my budget is around £750 which is $1211 but the prices of parts could be higher! I have 2 monitors if that means anything!
The games I will be playing are:
Battlefield 4
CS:GO
Minecraft
COD
Crysis 3
Parts I think I will have in it:
CPU : Intel i5-4670k 3.4GHz (I will be overclocking)
Storage: 1TB WD caviar black
Storage: 120GB Samsung 840 EVO
Memory: 8GB of corsair vengeance RAM
Case: Fractal design R4 case
but I don't really know what to get for the other parts. I was looking maybe at a gtx 770 gpu. And around 600W PSU! if you can please link parts from UK stores. To find these parts I used uk.pcpartpicker.com!
Thank you!
CPU: Intel Core i9-12900K 3.2 GHz 16-Core Processor | Cooler: Corsair iCUE H170i ELITE LCD 82.9 CFM Liquid CPU Cooler | Mobo: Asus ROG MAXIMUS Z690 HERO ATX LGA1700 Motherboard | Memory: Corsair Dominator Platinum RGB 32 GB (2 x 16 GB) DDR5-5200 CL40 Memory | GPU: Asus GeForce RTX 3080 10GB 10 GB STRIX GAMING OC Video Card | Storage: 1x Western Digital Black SN850 1 TB M.2-2280 NVME Solid State Drive + 2x Sabrent Rocket 2 TB M.2-2280 NVME Solid State Drive | PSU: Asus ROG Thor 1200P 1200 W 80+ Platinum Certified Fully Modular ATX Power Supply | Case: Corsair iCUE 7000X RGB ATX Full Tower Case | Keyboard: Filco Majestouch-2 | Mouse: Logitech G903
https://linustechtips.com/topic/240578-help-creating-a-gaming-pc/
Do you need an os and other periferals with it?
I dont need the OS or peripherals i have them!
Also are you planning on overclocking?
Yes, he has
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor  (£166.74 @ Aria PC)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  (£63.42 @ Amazon UK)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  (£74.39 @ Aria PC)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX Video Card  (£269.55 @ Amazon UK)
Case: Corsair Air 540 ATX Mid Tower Case  (£98.95 @ Amazon UK)
Total: £833.44
Generated by PCPartPicker 2014-10-28 19:43 GMT+0000
A bit over budget but all worth it IMO
Yes, he has
Total: £833.44
I'm on quite a tight budget but I might be able to. Is their anything you would change to make it cheaper?
I changed the case to the R4 which made it £20 cheaper, could I change the power supply? Maybe not fully modular?
PCPartPicker part list: http://uk.pcpartpicker.com/p/DPMLbv
Memory: Crucial Ballistix Sport XT 8GB (2 x 4GB) DDR3-1600 Memory  (£57.99 @ Amazon UK)
Storage: A-Data Premier Pro SP920 128GB 2.5" Solid State Drive  (£52.73 @ CCL Computers)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (£38.92 @ Aria PC)
Video Card: EVGA GeForce GTX 970 4GB ACX Video Card  (£255.19 @ Amazon UK)
Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case  (£69.59 @ Aria PC)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  (£43.32 @ Amazon UK)
Total: £747.90
Generated by PCPartPicker 2014-10-28 19:55 GMT+0000
Made Edits to reduce the price and give you better gfx
Having problems with your fresh Windows 10 install? PM Me!
Windows 10- Want To Disable Telemetry, Disable Cortana, Disable Windows Updates? Look at my guide HERE
LTT Beginners Guide  | Community Standards | TN&R Posting Guidelines
Total: £747.90
CPU cooler?
CPU cooler?
if you dont OCing or just low level OCing, you dont really need an after market CPU Cooler. Using the stock one that come with the CPU is fine. If you do low-mid level OCing, get a 212 EVO or Plus, they are one of the cheapest but very good air cooler. About 20$
My rig: Intel Core i7 4790k | MSI Z97 PC Mate | GSKILL Ripjaws X 16GB 1866MHz | ADATA Premier SP550 480GB SSD | Seagate Barracuda 3TB | Seagate Barracuda 2TB  | MSI Gaming X GTX 1070 | Thermaltake Versa N21 | Corsair CX550M Semi Modular PSU | AOC G2460PF 144Hz | Logitech G502 | GSKILL Ripjaws KM780  | GAMDIAS HEPHAESTUS V2  PCPartPicker | Old Build Log | New Build Log
Is this good? i would like to get my CPU over 4GHz
Be Quiet's CPU Cooler is good. But for getting CPU to 4GHz... it totally depend on the CPU. Some i5 4690k will be able to get to 4Ghz really easy, some will never be able to get there without cranking the voltage up. It's what we call silicon lottery :P
Also why would you need to OC so much?
So i can play the games I want to more smoothly! I also am going to do light editing!
Games wont even use up the stock 3.5 GHz, dont worry about it. For editing maybe.
So I dont need to overclock? I still want CPU cooler thought because I hate the look of the stock one lol!
Is this good?
http://uk.pcpartpicker.com/user/krazykaram/saved/FTqNnQ
Is this good?
Yeah, it still a good idea to get a CPU Cooler, and OCing should only be done when you actually use it and feel like it's slow.
The partlist is private so I cant see it
oops http://uk.pcpartpicker.com/user/krazykaram/saved/4C9nTW
Yeah, looks good
I'd get a MSI Z97 G45 motherboard instead, look much nicer + support SLI, yours dont. Also get the i5 4690k, not the 4670k. You can also change the Ram to some other color if you want your build to have a color scheme to it.
Get a GTX 970 instead of a 770
I cant get a 970 as it isnt in my price range :(
It's only about 25 GBP more right? Please try to save up abit more to get it :P It's way way better than the 770.
Also the i5 4690k is about 3-5GBP higher I think? but if you cant it's ok. You can also get a MSI Z97 PC Mate Motherboard, which is way cheaper than the G45 but still support everything you need except SLI, like the ASUS one you choose before. You can get a 970 that way :P
I can get the upgraded cpu and mobo just not gpu atm. yeah the gpu is 25 more but the shipping and it being refurbished! I will upgrade to a 970 later then btw can u SLI with a 970+770 or do they have to be the same? I have never done a build with SLI!
please edit it in any way you think will make it better! Please try only from amazon or any free shipping!
