I am going to upgrade some parts of my PC.
I want to play games like nfs rivals,bf4,crysis 3 on low to medium settings at 1280x1024 resolutions.
My budget is 200-250$.
My Old PC:
Intel Core 2 Duo e4300
Biostar G41D3+
Nvidia 8400GS
4 GB DDR3 RAM.
I want to buy R7 250 1 GB DDR3....but would that bottleneck my CPU????Should i buy a core 2 quad???
https://linustechtips.com/topic/240390-pc-upgrade-help/
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/240390-pc-upgrade-help/#findComment-3295448
Thats not what i asked for -_- I asked whether i need to change my CPU
https://linustechtips.com/topic/240390-pc-upgrade-help/#findComment-3295453
Pretty much the whole thing will need to go.
Best idea may be a 7850K + motherboard + RAM depending on prices.
https://linustechtips.com/topic/240390-pc-upgrade-help/#findComment-3295460
But im telling you your money can be spent better on a beefier GPU. After wards save money for an i5. But you'll have to live with a bottleneck for awhile. Trust me go with this route.
And yes your CPU needs to be changed. NEED.
https://linustechtips.com/topic/240390-pc-upgrade-help/#findComment-3295473
Actually i need a PC to play games for 2 months.So i don't need a future proof or something like that.Just help to build a PC that will last for 2 months.Thanks.......
Is there really a point in spending money on a 2 month life cycle PC?
https://linustechtips.com/topic/240390-pc-upgrade-help/#findComment-3295505
Yes...because with my current settings i wouldn't be able to play games like bf4,nfs rival,crysis 3.....
Yes... but why 2 months? For $250 there isn't much you can do to your PC to make it play games well.
https://linustechtips.com/topic/240390-pc-upgrade-help/#findComment-3295521
Because after 2 months i would go to a different place and would be there for 5 years.And i wouldn't take my desktop there.
To be honest I'd just live without playing those games for 2 months and keep the $250, there really isn't much you can do to make that desktop game worthy.
https://linustechtips.com/topic/240390-pc-upgrade-help/#findComment-3295583
