Specs
i7 4770k
Asus maximus v formula
Gtx 780 ti (going to watercool 2nd one soon)
Rm1000 (not in build because I literally jus finished build
Watercooling parts
Alphacool 360/240 rad
Swiftech apogee asus rog edition
Bitspower fittings
Bitspower gpu block
Phobya reservoir
Noctua fans on both rads
Primoflex tubing
Swiftech mcp655 pump
Will post pics of system on later
It was first time watercooling and scary at first finished it in two weeks cuz of work can't work on it all day and too tired at night to work on it but finished it and happy I will watercool my 2nd card in a week or two and I wudd recommend people to do planning before hand my dumbass didn't know alphacool xt45 didn't fit on top so u can't tell but fans are on top of case but yea comment on what u think I should change or if u like it or not thx
http://imgur.com/l5qALx4
http://imgur.com/pcjcpcy
http://imgur.com/Q1SiJF0
http://imgur.com/tk3WA0f
http://imgur.com/YvBracd
http://imgur.com/1yQTJAt
http://imgur.com/S7zK1OB
System Specs~~~~~
Case-Corsair Air 540                                   CPU-i7 4770k                           Ram-Corsair Vengeance 16 Gbs    PSU-Corsair RM1000
Motherboard-Asus Maximus VI Formula    Graphics-Asus Gtx 780 Ti x2     CPU Cooler-Corsair H100i               SSDs-Corsair Force GS 128/360 Gb
https://linustechtips.com/topic/239929-first-watercooled-build/
Looks good, how much did you pay for everything?
like 600 or 700 that included next day shipping
System Specs~~~~~
https://linustechtips.com/topic/239929-first-watercooled-build/#findComment-3289996
Are you kidding me? Does that include the custom water loop?
oh u meant for the whole build I don't remember I bought it when like the 780 ti first came out so I paid like 1200 for the graphics cards the 2nd one is out of the build because jus in case I broke one with doing watercooling still have 2nd one but yea that was for the loop only
System Specs~~~~~
https://linustechtips.com/topic/239929-first-watercooled-build/#findComment-3290015
Also my phone doesn't do it justice the red is actually more brighter than that
System Specs~~~~~
https://linustechtips.com/topic/239929-first-watercooled-build/#findComment-3290030
