Hey guys.I have extremely slow internet provided by eircom in Ireland.Download speed is 5mb/s max.Everything downloads at 500Kb/s and i ordered express vpn and i have a question if its possible to have much higher download speed than eircom? I tried to download files and the speed goes up to 300-400kb/s and i connected to uk/ireland/netherland servers and its just the same.Do  you know a solution for me? Thanks.
I5-4690K 4.7GHZ/Corsair H105/16GB Corsair Vengeance 2133Mhz/Asus VII HERO Z97/Evga 980 Ti Hybrid(soon)/Evga G2 750W/NZXT H440/Samsung 840 250Gb/WD Blue 1Tb/Logitech G502/Corsair K70 Blue switch/Logitech z4/Dell u2414h/Sennheiser HD650 With O2 Amp and ODAC/Mic-ISK-CRU1
https://linustechtips.com/topic/239300-vpn-help/
no its not.
your connection to the internet is only so fast, using a vpn doesnt make it faster.
it can only help if your provider throttles some traffic like netflix in the us.
https://linustechtips.com/topic/239300-vpn-help/#findComment-3281468
You can't increase your internet speed. if you are paying for more than 5mb/s than there is probably a "bottleneck" in the isp's network hub or the area around you. Getting a vpn will not help you get around the problem as it can only go as fast as your internet connection allows. Also if your files download at 500kb/s, make sure its Kb not KB. because there is a big difference there. Hope this helps :)
https://linustechtips.com/topic/239300-vpn-help/#findComment-3282791
