Gtx 980 cooling
Go to solution Solved by the jolly roger,
But I want to water cool it
well that is another story, with watercooling you can OC the SHIT out of it, specially with such an efficient chip like maxwell.
most waterblocks come in a waterblock/backplate combo, with backplate are usually for dat bling bling
Nope the reference cooler should be good enough depending on your OC.
<p>CPU: AMD FX-8320 @ 4.0 GHz | GPU: Asus GTX 970 STRIX | RAM: 8GB (2x4GB) Corsair Vengeance LP 1600MHz | Motherboard: Gigabyte GA-970A-UD3P ATX | SSD: Samsung 840 EVO 500GB (Boot Drive) | HDD: 500GB | Case: Corsair SPEC-02 Red |PSU: Corsair 750W | OS: Windows 7 64-Bit | Mouse: Corsair M65 (Black) | Keyboard: Corsair K95 RGB (Black w/ Brown Switches)
https://linustechtips.com/topic/239120-gtx-980-cooling/#findComment-3279376
He said that he wants to water cool it, he wasn't asking if he needed to water cool it to overclock it.
https://linustechtips.com/topic/239120-gtx-980-cooling/#findComment-3279399
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/239120-gtx-980-cooling/#findComment-3279407
You don't need a back plate but if you like the way it looks then get one.
https://linustechtips.com/topic/239120-gtx-980-cooling/#findComment-3279484
