First build? Help?
Solved by Guest,
Yeah
I can make it a bit cheaper (Swap the gpu or drop the SSD) if it is too much over budget.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor (£174.99 @ Ebuyer)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (£23.86 @ CCL Computers)
Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard (£88.76 @ Scan.co.uk)
Memory: Kingston Fury Red Series 8GB (2 x 4GB) DDR3-1866 Memory (£62.40 @ CCL Computers)
Storage: Crucial MX100 128GB 2.5" Solid State Drive (£51.00 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£39.38 @ CCL Computers)
Video Card: Asus Radeon R9 290 4GB DirectCU II Video Card (£209.99 @ Amazon UK)
Case: Phanteks Enthoo Pro ATX Full Tower Case (£88.33 @ Scan.co.uk)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply (£94.99 @ Amazon UK)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer (£10.09 @ CCL Computers)
Total: £843.79
Generated by PCPartPicker 2014-10-26 00:01 BST+0100
The 850W psu would allow for a 2nd R9 290 at a later date. If you only plan on a single gpu then a 550W would be enough.
The Phanteks is a very good case. It has better airflow than the 750D as well.
