[Java] Palindrome App Won't Work. Help.`
Go to solution Solved by fizzlesticks,
You initialized reverse to a space, it should be an empty string.
My code is.....
class Palindrome
   public static void main(String args[])
       String word, reverse = " ";
  EasyReader input = new EasyReader();
  System.out.println("Input a word");
  word = input.readWord();
  int length = word.length();
      for ( int i = length - 1; i >= 0; i-- )
         reverse = reverse + word.charAt(i);
      if (word.equals(reverse))
         System.out.println("It is a palindrome.");
      else
         System.out.println("It is not a palidrome.");
No matter what word I input, I always get back the else SOP.
CPU: Intel Core i7 2600k | Mootherboard: ASUS P8z68v-Pro | GPU: EVGA GTX780Ti 3GB | RAM: Kingston HyperX Genesis 8GB (4GBx2) 1600mhz | PSU: Corsair AX760 | STORAGE: Samsung 840 Pro 512GB | COOLER: Noctua NH-C14 | CASE: Fractal Design Define R4 Pearl Black | Operating SystemWindows 7 Professional 64-bit |
https://linustechtips.com/topic/238552-java-palindrome-app-wont-work-help/
Thanks. I feel stupid now, I stared at it for like 2 hours wondering what was wrong.
