Hi, i'm trying to mod my pc with some RGB lighting.... but i do not know enough to find some good solutions, so if you coult get me some tips for where to look for RGB controllers and light strpis, maybe som regular RGB leds i would be very peased.
You might wanna have a look at the NZXT hue: http://www.nzxt.com/product/detail/98-hue-case-accessory
I personally would recommend UV stuff, because the colors pop better.
"Use the force Harry"
                   -Gandalf
im using my front fan controller to control brightness of my 3pin led.
I know icemodz.com has RGB led strips plus a remote control for brightness, lighting modes and color changing.
Corsair 750D | Asus Crosshair V Formula-Z | FX 9590 | Kingston HyperX 16GB@1866MHz | MSI R9 290X Lightning | Seasonic 1050W Platinum | 2x WD 3TB Green HDD | Samsung 840 Pro 256GB SSD | Crucial 512GB SSD
Alphacool XT45 360mm | Alphacool Monsta 280mm | Silverstone AP121 | Silverstone AP141 | EK Supremacy Elite | EK ASUS C5F-Z | EK R9-290X Lightning | EK 3/8-1/2 Nickel | XSPC D5 Acrylic Tank | Primochill 3/8-1/2
Thank you for the tip, but i have allredy checked the "NZXT HUE" i personaly want a set up with a remote controll or a app for my phone.
Ahh ok, I have no clue about that, maybe somebody else does.
Good luck though  :)
                   -Gandalf
