Latest NVIDIA driver problem?
Go to solution Solved by ShadowCaptain,
I would try reinstalling geforce experiance and try reinstalling the latest driver again
I just uninstalled it and tried reinstalling but it still didn't work :/
Go into device manager, find the GPU and "uninstall" then use device manager to find a driver
after that redownload geforce experiance and try again
So I was excited for the DSR update and when I was installing it an error came up saying that it cannot continue with a yellow warning sign but not stating what was wrong after. Does anyone know what's wrong and can they help me?
Thanks. Image is also attached of the error screen
post-44934-0-30054700-1414077697_thumb.p
https://linustechtips.com/topic/237751-latest-nvidia-driver-problem/
Did you uninstall the previous driver first? After that is done just re-download it from the website.
CPU: i7-4770k @4.8ghz---Motherboard: Asus Sabertooth z97---Ram 32gb Corsair Vengeance---GPU: 2 EVGA GTX 980 4gb way sli---Case: Corsair 600T White---Storage: 500gb 850 Pro & WD Black 4tb---PSU: Corsair RM1000
Ok so I went to device manager to uninstall then find it again. I uninstalled it but now it isn't recognising my GPU anymore
Ok now download geforce experiance and install the drivers from NVIDIA
Now in geforce experience it says it flat out can't find a driver for this pc. This is pretty confusing now :/
Did you restart after uninstalling the driver?
It should show up in device manager somewhere, or click the "detect new hardware changes" button in device manager
DDU sometimes can get rid of any pesky driver files lingering in your system.
http://www.wagnardmobile.com/DDU/downloads.html
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
