Will Dynamic super resolution lower fps? i have a gtx 970
System
CPU: Intel Core i7 5820K @4.5GHz - 1.230v  RAM: HyperX Fury DDR4 4x4GB 2666MHz  MB: MSI X99S SLI PLUS  CASE: NZXT H440  CPU-COOLER: Fractal Design Kelvin S24  PSU: Corsair RM1000W w/ white sleeved cable kit  GPU: MSI GeForce RTX 2070 ARMOR  MONITOR: LG 27GL850-B  STORAGE: Samsung 970 EVO 1TB M.2, Samsung 840 EVO 256GB,  WD Red 3TB
https://linustechtips.com/topic/237559-will-dsr-lower-fps/
Yes by about 4 times.
https://linustechtips.com/topic/237559-will-dsr-lower-fps/#findComment-3257289
Of course it will.  Massively.  It's only meant for stuff like Dota 2/LoL where it's not too graphically intensive and you have GPU performance to spare.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/237559-will-dsr-lower-fps/#findComment-3257327
Like all above said. Yes, so the only reason to use DSR is if you wanna make some old/less demanding games to get a little bit more eye candy or if they don't support any type of AA.
On recent games will be preferable to actually play with AA before going the DSR route.
https://linustechtips.com/topic/237559-will-dsr-lower-fps/#findComment-3257411
