R9 270 temps
Go to solution Solved by NicekillBG,
So when it gets to 70 degrees Celsius its not a problem
with twin coolers it will be ok and buy an air conditioner nad the problem will get solved :D
Just don't let it get above 80C. I own the exact same MSI Twin Frozr R9 270. When I have the fans on 100%, I get to 54C MAX in Battlefield 4, if I use the default fan profile that it comes with it gets to 67C MAX. Temps up to 80C should be good. But I would start worrying a bit if it got to 75C.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/237137-r9-270-temps/#findComment-3251706
So guys I live in Australia and it gets pretty fucking hot and I was wondering what are safe temps for my MSI R9 270
Cheers :D
Depends, are you living in a corrugated iron shed in Darwin with no windows? If not, then you should be right. If you don't use air-con then it might not be advisable to overclock during summer when it gets 40+. Other than that, that 270 should have no probs with in a case with half competent cooling.
"Fighting for peace is like screwing for virginity"
- George Carlin (1937-2008)
https://linustechtips.com/topic/237137-r9-270-temps/#findComment-3251711
Its important to know whether that's 70°C at 100% GPU usage, or idle, or 50%, or what. 70°C at full load is fine, pretty good even. But you wouldn't want it to get hotter than about 80 very often.
https://linustechtips.com/topic/237137-r9-270-temps/#findComment-3251778
