I need help choosing one of two builds that I have made under a budget of 200$ I have every part except the CPU and RAM. The purpose of this build is a medium end gaming pc. Here are the two options.
Build #1
Intel Core i3-3220 Dual-Core Socket LGA1155 3.30GHz
$119.50
ADATA Premier Series 4GB (2x2GB) DDR3 1333MHz
$22.99
TOTAL = 142.49
TAX 13% = x0.13 18.52
FINAL = 161.01
Build #2
Intel Pentium G850 Dual-Core Socket LGA1155 2.90GHz
$79.99
Corsair XMS3 Classic 8GB (2x4GB) DDR3 1333MHz
$43.99
TOTAL = 123.98
TAX 13% = 16.11
FINAL = 140.09
I am leaning more towards the Build #1. Heres the list of the parts i have currently
GPU - Zotac GTX 560Ti OC
MOBO - H61M - P31
PSU - 460W Cooler Master
CASE - BitFenix Shinobi Window White
STORAGE - 500GB Western Digital
https://linustechtips.com/topic/2366-build-1-or-build-2/
Build 1 and 8 gigs of slightly faster ram.
PC 1: CPU: i5 12600k     GPU: RTX 4080     MOTHERBOARD: Asus B650M-A D4       RAM: 16x4 DDR4 3200       POWERSUPPLY: EVGA 650 G6
SSD: WD Black gen 4 x2 + Crucial MX 500 x2
KEYBOARD: Keychron K4    MOUSE: Logitech G502 SE Hero   MOUSE PAD: Goliathus control XL   MONITOR: Alienware AW3423DW + LG 25UM58 + Dell 24"  Speakers: Edifier R1280T + SVS PB1000
Laptop: M1 MacBook Pro 16
https://linustechtips.com/topic/2366-build-1-or-build-2/#findComment-32728
Leaning towards build one, but I would like you to look at microcenter's prices as their i3 3220 is 20 dollars cheaper which might allow you to get the 8gb ram.
http://www.microcenter.com/search/search_results.aspx?N=4294966995&D=core_i3&ekw=i3&rd=1
"No signature"
https://linustechtips.com/topic/2366-build-1-or-build-2/#findComment-33139
