vb 2008 about box problem
Go to solution Solved by CripDawg,
It's been awhile.
I think About will open the actual windows-generated about. Not the about.vb you are creating?
(I  am probably wrong...)
for some reason the icon that i chose still remained though
im trying to create a about box for my program so i edit the text on the about box but when i run the program and open the about box the same text i put in does not appear
It's been awhile.
D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200
