http://pcpartpicker.com/p/J7knNG
Ok so I'm pretty new to PC building so just want to know if this is a good average gaming PC that would last me a while, and if i need to change/ add anything onto what I have already put in there.
I'm pretty unsure about if these parts would work well together.
thanks.
I thought I said this, but it seems I didn't D: I live in Sydney Australia. hope this doesn't change much.
I also forgot to mention that i have this case www.antec.com/product.php?id=705131&fid=5022020
sorry for any inconvenience.
https://linustechtips.com/topic/236045-first-pc-build/
Yes they will work together, but you are getting stuff that is 1 generation behind.  Are you ok with that?  Ivy Bridge is as far as you will be able to go on the Z77 motherboard.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/236045-first-pc-build/#findComment-3234650
4690K Z97
PC : | CPU: Intel 4790K | COOLER: Corsair H105 w/ JetFlo's Push/Pull | MOBO: EVGA Z97 Classified | GPU: EVGA FTW 4GB GTX 970 X2 | RAM: Kingston HyperX Beast 1866Mhz 32GB | CASE: HAF Stacker 945 | PSU: Corsair AX1500i | DISPLAY: Asus MX299Q | SSD: 2 X Corsair Neutron GTX 480 GB in RAID0 | mSATA SSD: Samsung 840 EVO 500 GB | HDD: 4 X Western Digital RED 4 TB in JBOD |
https://linustechtips.com/topic/236045-first-pc-build/#findComment-3234654
2 generations behind Z77 - Z87 - Z97
https://linustechtips.com/topic/236045-first-pc-build/#findComment-3234661
PCPartPicker part list: http://pcpartpicker.com/p/BWVXhM
Price breakdown by merchant: http://pcpartpicker.com/p/BWVXhM/by_merchant/
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($174.99 @ SuperBiiz)
Motherboard: ASRock H97M Micro ATX LGA1150 Motherboard  ($75.66 @ Newegg)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($86.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($53.98 @ OutletPC)
Video Card: MSI Radeon R9 280 3GB TWIN FROZR Video Card  ($195.91 @ Newegg)
Power Supply: Cooler Master VSM 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($79.99 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($16.99 @ Newegg)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($90.26 @ OutletPC)
Wireless Network Adapter: Asus PCE-N10 802.11b/g/n PCI-Express x1 Wi-Fi Adapter  ($12.98 @ OutletPC)
Total: $787.75
Generated by PCPartPicker 2014-10-20 04:32 EDT-0400
The CPU is totally fine, you don't need an overclockable CPU. Also I chose a newer generation of hardware for you, and it will performa similar or better to what you chose above.
The GPU I chose on the other hand is MUCH MORE POWERFUL and I stayed in your budget. This will greatly affect your gaming performance.
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
https://linustechtips.com/topic/236045-first-pc-build/#findComment-3234682
Et voila!
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($199.99 @ Micro Center)
CPU Cooler: Zalman CNPS10X OPTIMA CPU Cooler  ($21.99 @ Newegg)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($79.79 @ Newegg)
Memory: PNY Optima 8GB (2 x 4GB) DDR3-1333 Memory  ($63.99 @ Amazon)
Video Card: HIS Radeon R9 280 3GB IceQ OC Video Card  ($169.99 @ Newegg)
Case: Corsair SPEC-03 Red ATX Mid Tower Case  ($39.99 @ Newegg)
Optical Drive: Lite-On iHAS124-14 DVD/CD Writer  ($13.99 @ Newegg)
Case Fan: LEPA Vortex 12 PWM 63.9 CFM 120mm  Fan  ($1.99 @ NCIX US)
Total: $780.92
Generated by PCPartPicker 2014-10-20 04:42 EDT-0400
https://linustechtips.com/topic/236045-first-pc-build/#findComment-3234730
Total: $787.75
Mine is better. Hi-Five! Also there is no case. OP made no mention of one, but better to ere on the side of caution don't you think?
https://linustechtips.com/topic/236045-first-pc-build/#findComment-3234746
You no fair. You usin Micro-Center pick-up! ;-)
Nah, good job man. Really good system.
https://linustechtips.com/topic/236045-first-pc-build/#findComment-3234904
