Well I just upgraded my pc with a new power supply and case. The spec are:
Corsair 500r case
Ms-7613 ver1.1 motherboard(lga1156)
Intel i3 550 cpu
Colamax gt640
Thermaltake 750w 80plus gold(tp-750p)
Adata 2x4gb 1600 ram
600gb hdd
I refer to the manu to plug in the front panal power switch but it just not working. But when I plug the power switch in the jbat1 header
https://linustechtips.com/topic/235666-computer-not-starting-up/
Personal Rig v3: AMD Ryzen 7 2700X | Noctua NH-U14S | Gigabyte B450 Aorus Pro ITX | Zotac GTX 2070 8GB | 16GB G-Skill Trident DDR4 3200MHz | EVGA Supernova 750B | Phanteks Enthoo Evolv ITX
Peripherals: Sennheiser HD518 & Classic ModMic | Corsair K65 Luxe | Zowie EC2 | ASUS VG259QM  |  ASUS VG278E | Klipsch ProMedia 2.1
https://linustechtips.com/topic/235666-computer-not-starting-up/#findComment-3229099
Corsair 500r case
Intel i3 550 cpu
Colamax gt640
600gb hdd
Probably just the case power button pinned on the motherboard correctly. I had that issue last time I built my system. Those pins are really damn annoying.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/235666-computer-not-starting-up/#findComment-3229112
