24-pin issue?
Go to solution Solved by VIhul,
That missing pin should be missing if it is a newer powersupply. That pin was used for the -5 Volt wire that was a left over from the AT days and it was removed from the ATX standard quite some time ago.
Your explanation is a bit vague, does your computer not work at all? Or does the restart button in windows not work?
Can you tell us a bit more about your system as well as anything off that might have happened recently?
Finally got it working after re-re-seating EVERYTHING. Thanks for your help guys.
So my computer refuses to restart (turned it off then back on, not hitting restart in Windows) and started re-seating all my cables when I noticed that the 5th "pin" from the right side of my 24-pin, with the clip side up, was missing. I've known this since day one, but my computer has booted fine until now. Could this missing pin be the issue?
By pin I mean the metal that surrounds the pin on the Mobo.
https://linustechtips.com/topic/235619-24-pin-issue/
I don't think I've ever seen a 24 pin with that cable actually there.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/235619-24-pin-issue/#findComment-3228492
https://linustechtips.com/topic/235619-24-pin-issue/#findComment-3232798
