Okay. I am slowly but surely saving up for a new machine of the desktop variety. I wanted to save and try to build a rig, but that will likely take much more time than my laptop has left. What I want is something that will last for at least five years and will be good for gaming, drawing, and editing videos (nothing major). Would you all consider this computer suitable?  http://www.newegg.com/Product/Product.aspx?Item=N82E16883227510
https://linustechtips.com/topic/234590-need-informed-opinions/
NO you can build a better one for that money
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/234590-need-informed-opinions/#findComment-3211777
That's your budget?
https://linustechtips.com/topic/234590-need-informed-opinions/#findComment-3211786
MY 1001st POST :D
yeah. around $500. I work minimum wage and most of my money goes to bills so...I don't feel like I will be able to save up much more than that before my laptop becomes completely unusable.
Does this include peripherials?
"an obvious supporter of privacy"
https://linustechtips.com/topic/234590-need-informed-opinions/#findComment-3211905
Is your budget 500$?
Give us aims for the build, and we will condig a build for you ;)
I assume that you can build a PC, right?
i have never built a computer before. i would like to, though. i watch a lot of videos and am trying to learn. my budget is around $500. maybe a bit more. "aims for the build"?
https://linustechtips.com/topic/234590-need-informed-opinions/#findComment-3211910
MY 1001st POST :D
peripherals need not be factored in at all. i still have that stuff from my old desktop. *edit* wait wait. i did not realize that "peripherals" included graphics cards and ram. i guess some will have to be factored in. i won't need a monitor or keyboard or mouse or anything like that. i have no idea if i could use the ram from my old dell dimension.
https://linustechtips.com/topic/234590-need-informed-opinions/#findComment-3211936
you think so?
Yea, that thing is horribly specced.
Here is a system http://pcpartpicker.com/p/qhpMyc didn't pick a case because I don't know what you like but that is build with plenty of budget left over for a case and an OS from G2A. So you can come in right at your $500 budget.
Edited- Just saw that you didn't need peripherals.
https://linustechtips.com/topic/234590-need-informed-opinions/#findComment-3211938
Here's something around $600 that's WAY WAY WAY better.
CPU: AMD FX-8350 4.0GHz 8-Core Processor  ($169.98 @ OutletPC)
Motherboard: ASRock 970 Extreme3 R2.0 ATX AM3+ Motherboard  ($59.99 @ Micro Center)
Video Card: Asus Radeon R9 270 2GB DirectCU II Video Card  ($153.98 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case  ($39.99 @ Micro Center)
Total: $617.90
Generated by PCPartPicker 2014-10-17 15:52 EDT-0400
https://linustechtips.com/topic/234590-need-informed-opinions/#findComment-3211939
What are you going to use the PC for?
read the OP "gaming, drawing, and editing videos (nothing major)."
https://linustechtips.com/topic/234590-need-informed-opinions/#findComment-3211983
is a good deal. the only thing that is bad about, is the graphic card.. take it and later on buy a better gpu. and 4more gb of ram. as you can see is under $500.. and gives you windows and everythign. you can't do under $500 and better than this, with case, windows, keyboard mouse etc. take it and as i said, later on buy a card and add more rams.
The blood on to your heart start pumping faster when you notice me.
But is ok.
Judge me for my nickname, my avatar and for the low amounts of posts I have. I will keep your heart beat raised.
https://linustechtips.com/topic/234590-need-informed-opinions/#findComment-3212208
Total: $617.90
I would go for this one, but if you cant:
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($62.27 @ TigerDirect)
Motherboard: Gigabyte GA-Z97MX-Gaming 5 Micro ATX LGA1150 Motherboard  ($116.97 @ OutletPC)
Video Card: HIS Radeon R7 260X 1GB IceQ X² Video Card  ($93.31 @ Amazon)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($54.98 @ Newegg)
Total: $496.48
Generated by PCPartPicker 2014-10-17 16:15 EDT-0400
https://linustechtips.com/topic/234590-need-informed-opinions/#findComment-3212246
what is your old system.. can you link the parts here, so i can combine and see what you can use or not..
But is ok.
https://linustechtips.com/topic/234590-need-informed-opinions/#findComment-3212300
that is rly nice, and old xD... look. is possible to make a better gaming pc around $500 but not able to add mouse, keyboard, and windows and 8gb ram. But as i told you. take the deal and latter on buy a better gpu like r7 265/270 and 4 more gb ram.
But is ok.
https://linustechtips.com/topic/234590-need-informed-opinions/#findComment-3217462
CPU Cooler: Zalman CNPS10X OPTIMA CPU Cooler  ($21.99 @ Newegg)
Motherboard: Asus A88XM-E Micro ATX FM2+ Motherboard  ($57.25 @ Newegg)
Memory: Team Elite Plus 8GB (2 x 4GB) DDR3-1333 Memory  ($65.99 @ Newegg)
Video Card: MSI GeForce GTX 760 2GB TWIN FROZR Video Card  ($179.99 @ Newegg)
Case: Corsair SPEC-03 Red ATX Mid Tower Case  ($39.99 @ Newegg)
Optical Drive: Lite-On iHAS124-14 DVD/CD Writer  ($13.99 @ Newegg)
Case Fan: LEPA Vortex 12 PWM 63.9 CFM 120mm  Fan  ($1.99 @ NCIX US)
Total: $557.15
Generated by PCPartPicker 2014-10-18 06:44 EDT-0400
This is great for the cash. Cheap and cheerful. A good mid ranged gpu with a mid ranged platform. for a budget price.
https://linustechtips.com/topic/234590-need-informed-opinions/#findComment-3218240
