Best Fan Configuration?
Cant have a side intake with my case. i was thinking just 3 exhaust on top?
I have the same case as you do. My system is not even close to being built but from reading quite a lot from the Owners' Club from overclock.net, this is what I'm going to do:
Front 200mm intake, leave it there.
Rear 140mm exhaust, leave it there.
I bought 3 Phanteks' fans to match the color and also because they were cheap when I bought them and I'm going to put all three on top, the frontmost one is going to be intake, the rearmost will be exhaust. With that, the system should have "zero" to slightly positive pressure so no dust there.
The top fan between those two, however, will only turn on when the system is under load. That should leave the rig with a slightly negative pressure when it starts to spin so hopefully temperatures are better as the (hot) air will get out faster.
I think this is a good config because you are cooling both the GPU and HDD areas (which I will need proper cooling) with fresh air from intake fans and the CPU cooler (NH-D15) is going to spit all that hot air out through the rear and top fans. The middle fan that only turns on when under load and supposedly will make my temps better perhaps is not even needed but I already bought it so why not.
I would be careful with bottom as intake because it disturbs the airflow to the GPU area... Anyway, testing different layouts until you find the best one is always the best thing to do.
Good luck and have fun.
