recently got another 4GB of RAM for my PC. Its exactly the same as my other stick of RAM (Corsair 1333mhz). I installed and my PC turns on but there's no display. But when I take 1 stick out and leave 1 in, my PC boots fine. I tested to see if the new RAM was faulty so I took my old one out and left my new one in and it boots up fine so the new RAM isn't faulty. I need help please,
Thank you.
P.S, my specs are:
AMD A6-5400K
asrock fm2a75m-dgs motherboard
Update: I tried increasing the voltage on the RAM slots and it worked but it only recognized one of the RAM sticks (4GB)
I still need help.
Thank you
https://linustechtips.com/topic/233469-ram-upgrade-problem/
run then ram is dual channle mode if its not.
Here is the slot layout example:
11111111111111111111111111111111111111  USE
33333333333333333333333333333333333333
22222222222222222222222222222222222222  USE
44444444444444444444444444444444444444
fill slots one and two first. but consolt your manual to see what ones are 1, and 2. or it might say on your mobo.
nvm its only a two slot mobo...... get a new one, that sucks anyways
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
https://linustechtips.com/topic/233469-ram-upgrade-problem/#findComment-3190438
It could be that you have a faulty ram slot or that you simply didn't match EXACT dimms with each other. I find it's always beneficial to get the exact amount of ram you need (and can afford) as soon as you build your system because it's hard(er) to upgrade ram by adding more sticks (as opposed to new kits).
Edit:
Try to boot up with one dimm in one slot, then try the other slot and do the same. That way, you can at least try to rule out faulty ram slots.
i5 2500k+Noctua NH-D14 - 8GB HyperX Blu - 240GB PNY XLR8 - Sapphire Reference 7970 - P8Z68-V Pro/Gen 3 - OCZ ZX 850W
Unlike *some* people, I do not claim to be an expert computer guru.  When I make mistakes, I apologise and I own up to them.  Then, I continue to learn so that I may provide those in need with educated answers to the best of my ability.
https://linustechtips.com/topic/233469-ram-upgrade-problem/#findComment-3196692
