i need water cooling for my new rig
cpu : core i5 4460
ram : 16gb
gpu : gtx 750 ti
mobo : asus h87 plus
water cooling budget : $100
i intend to take h100i , is h100i good ? how much it will the low the temp of the cpu ?
What is your rig for?  It is very unbalanced.
Go with only 8GB of RAM.  Get a better GPU.  Skip out on after market cooling if you are going with a locked processor.  Avoid the H100i, it has a really bad problem with mounting.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/232874-water-cooling-help/#findComment-3182675
unbalanced ?? i order the parts. i can change. what do you suggest ? for 1366x768 resolution i think gtx 750 ti is fine.
so locked processor doesn't need after market cooling ?
In order for someone to see that you have replied, you need to quote or "@" them.
1366x768 resolution?  Maybe buy a 1080p monitor, you can get really good ones for $120.
Locked processor doesn't need after market cooling. No.
16GB of RAM is way overkill.  You only need 8GB for gaming.
Yes, a 750Ti is good for that resolution, but this is 2014, almost 2015.  You really should be on 1080p.  I recommend the R9 280 for $150.  It is a MUCH stronger card than the 750Ti.
What is your overall budget, location, and use for the machine?  Do you have any parts already?  Do you need operating system, mouse, keyboard, speakers, monitor?
https://linustechtips.com/topic/232874-water-cooling-help/#findComment-3183087
@Archangell, That's true, I bought mine for a prize like that, i calibrated it, and i got a 98% RBG color gama.
changing to 1080p is realy awsome, it is not only sharper, but it also gives you much more room to play with in applications, I love it :)
greets
https://linustechtips.com/topic/232874-water-cooling-help/#findComment-3183277
@Telhma, greetings.. is ASUS VX229H good ? is $170 here ( included vat+delivary costs)
here is link : http://pcworldrajshahi.com/142/PC-Hardware/Monitor/VX229H#.VD04EcnzKdQ
Spend the majority of your budget on core components.  Later you can upgrade your monitor.
What kind of games do you play?
https://linustechtips.com/topic/232874-water-cooling-help/#findComment-3183600
I do not realy know, I do not play games a lot, so i do not care about the framerate and things like that. so i think better somebody else helps you with the screen that suits your needs :)
But, like @Faceman says, first find something that can run a 1080p screen att the setings you want it to run before you go buy one. but i think your graphic card needs to be just able to do that.
I use a 660 (gigabyte stock speeds), I think it's rated just abouve your card, but i can play Guildwars att 60FPS with highest settings, keep in mind for most of the screens you do not need framerates faster then 60FPS.
I do not know how you can test out if it will work or not :(
https://linustechtips.com/topic/232874-water-cooling-help/#findComment-3183731
Yes, its a good monitor.  Instead of hijacking someone else's thread, create your own topic in the Display section of the forum.
https://linustechtips.com/topic/232874-water-cooling-help/#findComment-3184010
@Faceman,
dragon age : inquisition, far cry 4 may be bf : hardline not sure
Can you send me a link to a website that you will use to purchase parts please?
https://linustechtips.com/topic/232874-water-cooling-help/#findComment-3184013
@Faceman , case : http://pcworldrajshahi.com/71/PC-Hardware/Case/Carbide-200R#.VD1UYcnzKdQ
ram : http://pcworldrajshahi.com/26/PC-Hardware/Memory-Module/Vengeance-8GB#.VD1UZcnzKdQ
processor : http://www.ryanscomputers.com/Intel-4460-C-4858
mobo : http://www.ryanscomputers.com/Asus-H97-Pro-5399
gpu not sure may be GTX 770 or 760 or 750 Ti, if 750 Ti i will keep my current psu, if not then
psu :  http://www.ryanscomputers.com/Corsair-600W-3082
these are my country website and shop they are 1$15 to $ 30 more than US price.
https://linustechtips.com/topic/232874-water-cooling-help/#findComment-3184197
Everything looks good.  Only thing I would change is the PSU and GPU.
Go with the Corsair VS450W PSU.  Unless if there is another website to pick from, because the selection is very limited. 450W is plenty of power for the 750Ti, even a more mid-range card like the 760/280.  Another good option is the Corsair CX500M
Everything else looks good.
https://linustechtips.com/topic/232874-water-cooling-help/#findComment-3184777
