Hi all, so I am having problems with my fps in Skyrim, but I have a pretty beastly rig:
i7 4790k
2xGTX980's in SLI
16gb or RAM
Here are the key mods I am running:
Purevision ENB
Skyrim HD 2k textures
lush grass and trees
Cinematic Fire
Glorious Grass
Ruins Clutter Improved
Static Mesh improvements
Vivid Landscapes
Skyrim Floral Overhaul
They all seem to work, but I only get around 30-40 fps with my two cards running in SLI, all anti-aliasing and anisotropic filtering disabled, and running at 1080p. Is this normal, or is there something wrong?
https://linustechtips.com/topic/232664-skyrim-graphics-mods-fps-issues/
First of all, your second 980 will only give youa bout a 10-15 precent boost (most likley)
What is your CPU clocked at? It makes a big diffrence
Skyrim ini and Skyrim pref settings?
ENB local settings?
Are you using SKSE? Along with the other fixes?
Did you clean your Skyrim.esm and all the DLC?
Do you have the other recommended stability  mods?
You don't need to answer all of those but those are the first places you should look.
My cpu is running at 4ghz and I am running SKSE. How do I change my Skyrim ini, pref settings, enb setti9ngs , and what stability mods do you recommend?
Have you gone through and deactivated mods one by one to see which might be affecting your performance the most?  Are there any other problems or is it just low frame rate?
I haven't played Skyrim in a while, but I remember SFO being a fairly large hit to performance under certain conditions.  Perhaps it isn't playing nicely with some of your other mods.
You might want to ask on Nexus if someone here doesn't have answers.
I suggest following the STEP guide as a baseline
http://wiki.step-project.com/STEP:2.2.9
For a more advanced guide
http://wiki.step-project.com/User:Neovalen/Skyrim_Revisited_-_Legendary_Edition
Other relevant guides
Skyrim Stability Guide
http://www.nexusmods.com/skyrim/mods/50244/?
Skyrim Graphics Guide
http://www.nexusmods.com/skyrim/mods/55921/?
Speed and Stability Guide for ENB
http://www.nexusmods.com/skyrim/mods/50214/?
Quickfix: Uninstall Lush Grass and Trees and Glorious Grass
