I need a new mobo and i dont know what one to get.
I have a amd fx 4350 cpu at the moment and im looking for a new motherboard that will let me have up to two gpus thats all i need.
im getting a corsair carbide air 540 which only has usb 3 at the front so i need the usb 3 header thing and i need room for a a sound card and wireless card definitley dont need ddr4 memory and im hoping to spend under a hundred pounds
any recommendations are most appreciated
https://linustechtips.com/topic/232559-motherboard-help/
An AMD FX-4350 will even bottleneck 1 mid/high end card, how the hell do you expect to run 2 properly?
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/232559-motherboard-help/#findComment-3178844
http://uk.pcpartpicker.com/part/gigabyte-motherboard-ga990fxaud3 is your best bet if you also want a possible upgrade to FX-8320
https://linustechtips.com/topic/232559-motherboard-help/#findComment-3178850
i didnt think it would bottleneck i just looked at the perfomance compared to a 8350 why would the 4350 bottleneck?
It's a really weak CPU
https://linustechtips.com/topic/232559-motherboard-help/#findComment-3178905
in what ways, does it do alright for gaming?
Not really. An intel CPU is preferable
https://linustechtips.com/topic/232559-motherboard-help/#findComment-3178926
i would love a intel cpu but dont think i could afford it, is a intel cpu much more expensive than amd?
Depends on which one you take. You could get an I3 but that will probably struggle with 2 GPU's (Not with one though).
https://linustechtips.com/topic/232559-motherboard-help/#findComment-3182019
well im thinking of staying amd as its cheaper and want the option for two cards and a better cpu later on so i think ill take that gigabyte one you suggested :) thanks for your help
https://linustechtips.com/topic/232559-motherboard-help/#findComment-3184832
