Need just a regular TV, no special features like Google integration or whatever, that's what a chromecast of htpc is for.Preferably something around 32 inches (or more if cheapish) and 1080p at least.
I was looking at this: http://www.newegg.com/Product/Product.aspx?Item=N82E16889005869 and it seems pretty good. Trying to find something really awesome and under, say, 400? 450?
CPU: Ryzen 5800X | GPU: RTX 3080 FE | Board: x570 Aorus Master | RAM: 32GB GSkill TridentZ | Case: Phanteks 719
https://linustechtips.com/topic/232122-help-me-find-a-tv/
that seemslike a good one for the price
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/232122-help-me-find-a-tv/#findComment-3173310
i bought a SCEPTRE X325BV-FMDR 32" tv.. you can find it from at the Walmart webstore. it pretty good for $200. It doesnt do anything fancy but it can have a roku streaming stick added and the TVs remote can work the roku. I guess it sgood if you want to have less remotes. I would not say this tv is really awesome but I just think 32" inch plus 1080p for $200 is pretty awesome.
𝘛𝘳𝘶𝘴𝘵 𝘺𝘰𝘶𝘳 𝘪𝘯𝘵𝘶𝘪𝘵𝘪𝘰𝘯
PC: ibuypower pre-built RDY Y70
Cpu: i9 14900K  Gpu: Zotac 4070 super ti  Ram: 32Gb DDR5  SSD: 2Tb
Case: HYTE Y70  MB: MSI 790-P wifi
Cooling: ibuypower 360mm RGB aio
Laptop: Lenovo Legion Pro 5i, u9 275HX, 32gb ddr5, 5070ti, 1tb SSD, 16" 165hz oled
https://linustechtips.com/topic/232122-help-me-find-a-tv/#findComment-3175056
