Your thermal paste could be worn out? the cooler may not be mounted correctly? your CPU coolers fans may not be running at a high rpm
Yes Yes Legalize Gay Marriage sure, but have you ever considered Weaponizing Gay?
CPU: I5 4690 3.5ghz || MOBO: MSI B85-G43 Gaming Board || RAM: 8GB Corsair Vengance Pro - Red || GPU: Gainward GTX770 Phantom 4gb || PSU: EVGA SuperNova 750W Gold || Case: Thermaltake Urban T31 || SSD: Corsair Force 120GB || HDD: 1TB WD Black
https://linustechtips.com/topic/232106-temps-not-idle-anymore/#findComment-3173047
I installed everything about a month ago, its properly mounted and idk why they would change rpm??
Are you sure it was idle? Not antivirus or updater doing something in background?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/232106-temps-not-idle-anymore/#findComment-3177581
