Question for Germans/Austrians/German speakers
NeatSquidYT
Hi,
So I'm revising for a vocab test for German on Tuesday.
1 question:
Is it das Sportszentrum or das Sportzentrum? Same goes for das Einkaufzentrum. Danke ;)
It's Sportzentrum, and I think Einkaufzentrum is the same. Just don't quote me on that, as I'm only learning german in school also
Specs: CPU: AMD FX 6300 Motherboard: Gigabyte 970A DS3P RAM: HyperX Fury 16GB 1866MHz GPU: MSI R9 270 OC edition Case: Sharkoon VS3-S SSD: Samsung 840 EVO 120GB HDD: 1TB Caviar Blue PSU: Corsair CX500W
*If I say something that seems offensive, please don't take it seriously, it was most likely meant as a joke/sarcastically*
Danke meine Freunde :)
From a german: Einkaufszentrum, Sportzentrum
I knew Sportzentrum was right, just wasn't sure about Einkaufszentrum :)
I'm German, this is correct.
Owner of a top of the line 13" MacBook Pro with Retina Display (Dual Boot OS X El Capitan & Win 10):
Core i7-4558U @ 3.2GHz II Intel Iris @ 1200MHz II 1TB Apple/Samsung SSD II 16 GB RAM @ 1600MHz
Actually, Eunkaufzentrum or Einkaufszentrum is a pretty tough question since you can hear people say both. But if you look at some of them online it always says Einkaufszentrum with the s in there, so I guess that's correct.
Feel free to ask if you have any other questions and good luck with your test.
Dankeschön :)
