Hey guys, just recently I put together a new PC and it should be at my House sometime soon. The case has 2 120mm Fans (one at the front, one at the back)
Over here in Australia it can get up to 50 Degrees Celsius, I was wondering in a room that is air conditioned down to about 30, 25ish how many more fans am i going to need to play it safe.
Also please reccommend some good fans that are 120mm
Thanks
Main PC/Gaming PC - G3258 @ 4.0GHz | Sapphire R9 280 3gb | 2x4GB Kingston Fury HyperX Blue 1600Mhz RAM | ASRock H97M Anniversary | x2 Seagate Barracuda 1tb | Coolermaster N400 Windowed | EVGA 600B 600W PSU | Windows 8
Keyboard, Mouse etc. - Razer Blackwidow Expert 2014 Green Switches | Logitech G502 Mouse | Logitech G430 Headset | Logitech C920 Webcam |
Screens - Acer K27HL | Acer S23HL | 32" Full HD TV (Don't know brand) |
https://linustechtips.com/topic/231670-australian-heat/
Use all the fan provisions in your case if you can...
It gets up to 42C here at worst and I'm only using 2 case fans... The PC can handle it... Barely...
https://linustechtips.com/topic/231670-australian-heat/#findComment-3167527
You should be okay if the room's below 30 degrees. (20-25 is pretty cool already)
What CPU cooler/GPU are you using,since that'll make more of a difference.
Remember to be a good citizen and choose a 'best answer' when your problem has been resolved!
(that way people know when a problem's been resolved)
https://linustechtips.com/topic/231670-australian-heat/#findComment-3167528
You'll be right. I got an overclocked i5 and an R9 280 with two 120mm fans and they do the job.
Is your case closed or have a mesh? If you're worried you can chuck another 80mm fan at the top if the case if there's provision for it.
PS.- 50 degrees down in VIC? Really?
"Fighting for peace is like screwing for virginity"
- George Carlin (1937-2008)
https://linustechtips.com/topic/231670-australian-heat/#findComment-3167613
Good 120mm fans would be Gentle Typhoon , Grand Flex and if you dont care about the noise Ultra Kaze and Delta fans would be for you.However if you are fancy and have lots of money Noctua
Grant us the joy of song and dance and ever watch over us in the lonely places in which we must walk - Pray to Bastet
https://linustechtips.com/topic/231670-australian-heat/#findComment-3171978
Thanks for the responses. I have another fan from my old CPU that I am going to mount somewhere in the case. Anyway, thanks for the reposonses. Talk to you guys later
https://linustechtips.com/topic/231670-australian-heat/#findComment-3174527
During the summer it can do 50ish, but most of the time it will be 35-40ish
https://linustechtips.com/topic/231670-australian-heat/#findComment-3174530
