Specs and pictures please
I need help, i connected the power supply, inserted the ram and all the rest. But my motherboard won't turn on. The CPU fan starts op but my keyboard led won't lite op and I saw noting on que panel
 CPU: AMD FX-6300     COOLER: Hyper 212 EVO    MOBO: ASUS M5A97 R2.0    RAM: Team Vulcan 8Gb (4Gb x 2) , G-Skill Sniper (4Gb x 2)    PSU: Rosewill HIVE-750w    GPU: ASUS HD 7790 2Gb OC    CASE: NZXT Phantom 410    STORAGE: WD Black 1Tb , Intel 530 120Gb     AUDIO: HyperX Cloud , Sennheiser HD 518 , Audio Technica ATH-M30 , Sennheiser MM30G , Yamaha RX-V361 , Pioneer SP-BS22     PHONE: Samsung Galaxy S7 Edge     PERIPHERALS: Razer BlackWidow Ultimate Classic , Logitech g502 ( Thanks Syntaxvgm <3 )
https://linustechtips.com/topic/231055-help-motherboar/#findComment-3160259
Take your RAM out and put it back in and if that doesn't work try to get a better picture of your mother board so I can see all of the connections.
http://i.imgur.com/L9kZq0y.jpg
http://i.imgur.com/CbH1i8y.jpg
http://i.imgur.com/HfI1tmo.jpg
http://i.imgur.com/dc2LhQy.jpg
http://i.imgur.com/hBm6sDj.jpg
https://linustechtips.com/topic/231055-help-motherboar/#findComment-3160671
Yes it is connected, my main problem is that i get no beeps, no usb power, and only fans and led when i trun off the pc
Try it with one stick of RAM and try it in each slot. Repeat that with any other sticks you have. This rules out had RAM and bad RAM slots.
https://linustechtips.com/topic/231055-help-motherboar/#findComment-3160832
What do your CPU pins look like. Its the #1 mistake of new builder is to bend them
There are two power cords. 24 pin and 4/8 pin for CPU power
Pull it all parts out of the case and bench test it. The second mistake is not installing standoffs or putting them in the wrong place
https://linustechtips.com/topic/231055-help-motherboar/#findComment-3166337
I will check the pins in a bit, but i was reading that the z97m-g43 supports the pentium with an update or something like that, is that the problem?
https://linustechtips.com/topic/231055-help-motherboar/#findComment-3166877
