Hello, it's my first post here and i need some help. I installed Linux Mint on my laptop in D: partition and everything went OK, but after the restart i don't get any boot menu to select an OS. Now when i start the laptop it loads windows 7 without asking me. I did some search and found out a solution, BUT it doesn't work.
Thanks in advance for any suggestions and help
Im using Live CD (it's a usb stick but..) and those commands :
sudo add-apt-repository ppa:yannubuntu/boot-repair && sudo apt-get update (after which i get quite a lot of errors)
sudo apt-get install -y boot-repair && (boot-repair &) ( after this command i get E: Unable to locate package boot-repair
https://linustechtips.com/topic/230682-problem-with-double-booting/
Sounds like you installed the boot loader wrong. It should be installed on the actual hard drive, not a partition.
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
What program did you use to "burn" the live USB?
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
Can you take a screenshot of the drive in Drive Manager? That would help us get a better idea of what's going on.
Are you missing the Grub2 boot loader menu? You might be able to repair it with this:
http://www.howtogeek.com/114884/how-to-repair-grub2-when-ubuntu-wont-boot/
If this isn't the problem can you please explain what it is.
"PSU brands are meaningless, look up the OEM."
This is a screenshot from disk manager and msconfig. When i installed Mint i choose the alongside option
http://postimg.org/image/r224tihen/
OK, i fixed it :) I deleted all the mint partitions and created new ones by myself. It's all working now. Thanks for the help thou
