I'm trying to lower the heat out put of my PC since its summer. I mostly use my to watch You Tube and Netflix which is far from taxing on my PC.
I have a t1090 and a Radeon hd 6850
Now would it be better to disable cores, lower the CPU ratio, lower the core clock, ect.
https://linustechtips.com/topic/23062-lower-temps/
I'd say under clocking is better, however that is like overclocking in the sense that you'll decrease the frequency, which then you'll decrease the voltage but you have to find what is stable,
Hey there. You are looking mighty fine today, have my virtual cookie!  :ph34r:
MY RIG: http://linustechtips.com/main/topic/34911-my-setup-gold-ghetto-gg-lots-of-pictures/#entry446883
https://linustechtips.com/topic/23062-lower-temps/#findComment-292076
That was my thinking but I wasn't sure if it was the best way(with out changing hardware)
https://linustechtips.com/topic/23062-lower-temps/#findComment-292108
Well I know that will lower temps, or you can do both if you think you won't be needing the extra cores.
https://linustechtips.com/topic/23062-lower-temps/#findComment-292163
