my friend have 1mb/s wifi speed and i have only 100kb/s internet speed. so i think somethings wrong with my settings. i need help for it guide my step by step ( if you have a link how to do it please share it ) please. my rounter is tp link TD-W8961ND i live in indonesia, bali
https://linustechtips.com/topic/230089-help-settings-with-wifis/
1. Are you talking about when you are on the same wireless network?
2. Are you doing speed tests at different distances from the router? try going near it and running a speed test, it is likely that your wireless card is at fault if that solves it.
3. those speeds are horrible...
https://linustechtips.com/topic/230089-help-settings-with-wifis/#findComment-3149109
1. same wireless network ? you mean like carier ( not carier it's LIKE carier ) if so and the answer is yes
2. the router is next to me so damn close and for my friend it's from his room witch is quite a distances and use wifi.. i have tested the ping even with cable the result are almost the same.
3. i know
https://linustechtips.com/topic/230089-help-settings-with-wifis/#findComment-3149183
3. i know
btw i forget to use quote to answer
https://linustechtips.com/topic/230089-help-settings-with-wifis/#findComment-3149195
3. i know
1. I mean are you connected to the same wireless router?
2. Perhaps your computer is older and uses a slower wireless card than your friends computer.
https://linustechtips.com/topic/230089-help-settings-with-wifis/#findComment-3149324
1.nope.. diffent house but i forget to mention that my friend is my neighbrough so it's literly a cross the street.
2.maybe but i think it's a long shot cus his computer is a lenovo that is still have a pentium 4.. and my laptop is 2012
and again
https://linustechtips.com/topic/230089-help-settings-with-wifis/#findComment-3149396
Perhaps your internet plan is slower than your friends, replacing your router would not speed up your internet if that is the case.
https://linustechtips.com/topic/230089-help-settings-with-wifis/#findComment-3151061
