No case needed. Just lay the device down on the table on keyboard side, and use a pouch to avoid scratching it.
As you use touch, you don't need a screen protector. But if you are interested in one. Get the Phantom Glass. It is literally a thin Gorilla Glass sheet that you put on your device. So the touch experience is the same, and it is perfectly clear, no tint that you normally get from normal screen protector, despite their claim (plastic is not perfectly transparent).
https://linustechtips.com/topic/229277-surface-2-case/#findComment-3138625
