Well, for decent recording, £50 is not going to get you far tbh. Samson C01u maybe?
But get the non-u (XLR instead of USB) version and a PhantomPower Supply if you can afford it.
If I were to get the co1 what phantom power supply would you recommend?
“Look at you soaring through the air majestically... like an eagle. Piloting a blimp.” - GLaDOS
https://linustechtips.com/topic/229197-recording-microphone/#findComment-3136921
Personally, I've got a £20 Behringer but it has no Mic pre-amp in it so I'm looking to upgrade to a Focusrite Scarlett - which is out of your budget :(
I think the best you could do with 50 quid is get the USB version and then maybe a popfilter and/or a spidermount.
https://linustechtips.com/topic/229197-recording-microphone/#findComment-3136963
If I were to save up a bit more say to £70 would that get me a lot better quality?
https://linustechtips.com/topic/229197-recording-microphone/#findComment-3137004
Hmm not sure. You could then bump it up to a C03 (u) with cardioid  recording (basically stereo) but it won't get you much better quality.
Maybe you can pick up an AT-2020 for that price if you're lucky :)
https://linustechtips.com/topic/229197-recording-microphone/#findComment-3137071
