Overclock Unstable After Adding Graphics Card
Go to solution Solved by laxer,
Likely the PSU...
So, I got my graphics card today, I put it in. Ran Prime 95 and Furmark, crashed. I tried just Prime95 and it crashed. Higher voltage, crash. Only setting it to stock made it not crash. This is was my overclock settings before and after adding the GPU.
CPU 4.4 GHz +0,090 for the CPU
RAM 2133MHz RAM voltage 1,60v
iGPU 1 ghz
NB 2000 mhz +0,072 for the NB
It was completely stable before the GPU. I have the GPU overclocked as far as it will let me (Core Clock: 1200MHz, Memory: 1575MHz) Rig is in my signature. Thanks for the help.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
iGPU 1 ghz
Get a stronger PSU it looks to be that your maxxing out your current PSU with the overclock on your GPU.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
I don't know if that's the issue. It didn't shutdown, it either freezes or bluescreens. The error it gets when it bluescreens is something like this "Clock interrupt not received within allocated interval"
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
This is consistent with bad power... Bad power can cause all sorts of strange issues. Borrow a PSU from someone and retest your stability.
Looking online it looks to be a softwear related BSOD, and if not its a hardware related BSOD.
|King Of The Lost|
I set my CPU and GPU click to default and everything seems to be running fine. I'll run the tests overnight and get back to you guys.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
Regardless of how the test turns out I would try a different PSU...
You are pretty close to the max output on your PSU which 1 is not good for it or anything connected to it and 2 is not very efficient.
Yeah, my next upgrade is to a 750W, but I don't get paid 'till the 29th. Defaults are working great.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
