2 Monitors, 1 Sound?
SlipperyBeen
Hi all,
I'm new here, my name is Dan.
I have 2 monitors and one graphics card(at the moment) and I want to play the same sound out of both screens.
is this possible? if so could you be ever so kind and explain how?
My rig is:
Processor: Intel 3.5GHz 5930k
Motherboard: Asus X99-Deluxe
Memory: 4 x 4GB(16GB) Corsair Vengence DDR4 2800MHz
GPU: Geforce GTX 980
CPU Cooler: H100i Hydro Series
SSD: Samsung 840 evo 1TB
Monitors: LG 29MA73V 29"
OS: Windows 8.1
Thanks in advance
Dan
So you want something like this:
http://www.amazon.com/ViewHD-Premium-Extractor-Converter-VHD-H2HSAs/dp/B00KBHX072
but with a DAC+AMP and then
http://www.amazon.com/RiteAV-293520-3-5mm-Splitter/dp/B000V1O1KS
to split that audio to both monitors if they both take a 3.5mm input?
A separate pair of speakers would be much less of a hassle and probably cost less.
Is there speakers in the monitors you want to play sound out of?
yes they both have speakers in and both are both running display port cables.
yeah im thinking speakers are going to be a better option. currently not that much space on the desk ive got!
